Mar1us79
Mar 12, 2014Follower
Very Slow Performance on RN104
Hello, I just plugged in 3x3TB HDD into ReadyNAS 104, but transfer files is around 7MB/s. I think this should be much much higher. RN104 is in RAID0 configuration to increese performance, but with ...
Mar 15, 2014Guru - Experienced User
Well, you can't get more than about 11 MB/s with the wrt54g, as it only supports 100 mbit ethernet. Over 802.11g wireless you won't get more than about 2.5 MB/s.
nas102 wrote: hi,
similar problem here, but worst.
RN102, FW 6.1.6, Win 7 x64
connect via homeplug (powerline)
read 700KB/s
write 1.3MB/s
direct ethernet cat 5e connect to same router (linksys wrt)
read 23.433503 MB/s
write 22.408892 MB/s
original with 6.0.0 FW, upgraded to 6.1.6 and reset settings.
tried different cat 5e cables with no improvement.
router linksys wrt54g
test connect via lan and wifi, all file transfer slow like turtle.
any idea what's wrong?
how to troubleshoot?
already followed the instruction in http://kb.netgear.com/app/answers/detail/a_id/12242
and used iometer to test.
Your iometer ~22MB/s results were not "direct connect" if you were connected through the router. "direct connect" means ethernet cable between the PC and the NAS with nothing in between. Also, your results suggest that you had too much buffering in the test configuration. Fast ethernet cannot carry 22 MB/s.
So the first thing to do is get a new router (gigabit ethernet + 802.11n or 802.11ac).
