Mar1us79
Mar 12, 2014Follower
Very Slow Performance on RN104
Hello, I just plugged in 3x3TB HDD into ReadyNAS 104, but transfer files is around 7MB/s. I think this should be much much higher. RN104 is in RAID0 configuration to increese performance, but with ...
Mar 20, 2014Guru - Experienced User
Since you are measuring about 200 mbits of throughput on a 100 mbit connection, the likelihood of the measurement being wrong is 100%.
nas102 wrote: the result of iometer test is 100% follow the instruction from netgear and also use config file provided.
how likely the test instruction provided is to deceive performance of the device in question?
Unless you have a different network setup than the one you outline in your post. For instance, if you have a gigabit switch or router, or if you were connecting the PC directly to the NAS (and not using the router in the iometer test).
I suggest retesting with nastester (you can download it here: http://www.808.dk/?code-csharp-nas-performance).
And getting a new router.
BTW, what powerline product are you using?
