darragh_buffini
Sep 21, 2011Aspirant
VERY slow transfer from NV+ to Ultra 4
Afternoon lads, I've trawled through the forums and gone slightly blind looking for solutions to this, so please forgive me if I've managed to miss the simple and obvious solution :) I am trying...
victorhortalive
Disable Jumbo Frames. If the router doesn't support MTUs above 1500, then it doesn't support Jumbo Frames.
If you can, you might also do the copying through the laptop rather than from NAS to NAS.
Try to get a Data Path of NAS to Router to Laptop to Router to NAS.
From your data it seems that the NV+ is operating at half speed, with the Ultra at also lower rates. I distrust the switching abilities of most Routers, yours included. Do you have a GB switch you can use ?
