darragh_buffini
Sep 21, 2011Aspirant
VERY slow transfer from NV+ to Ultra 4
Afternoon lads, I've trawled through the forums and gone slightly blind looking for solutions to this, so please forgive me if I've managed to miss the simple and obvious solution :) I am trying...
victorhortalive
Sep 23, 2011Aspirant
Only one Ethernet port on the laptop is needed. As long as there are enough ports on the router, only one wire is needed from each unit.
Connect both NAS units and the laptop to the router via Ethernet.
Your issue is network protocols and drivers, not the speed of the electrons as they zip up and down the wires. Also the speed of the drive in your laptop will also affect the overall rate. Hopefully this drive is 7200rpm ?
You might also install a network monitor programme and look at the "real-time" trace. I'll find the download URL and post it.
The programme I was looking for is Win only, so no help there.
