ReadyJabba
Feb 27, 2014Tutor
Video Stuttering / RN312 6.1.6 / Panasonic TV
Running 6.1.6 on a RN312 with DLNA and I am seeing videos pause/stutter quite regularly. Have had the same network setup with a Duo without this issue and 6.0.8 was fine on the RN312. It's not due to ...
ReadyJabba
Feb 27, 2014Tutor
Skywalker wrote: I have a hunch. If the Panasonic TV leaves more than 5 open connections, further connections will be rejected. We probably need to up that limit. Try this:
# wget http://www.readynas.com/packages/readynasos/dists/experimental/main/pool/m/minidlna/minidlna_1.1.2~6cef303-netgear1_amd64.deb
# dpkg -i minidlna_1.1.2~6cef303-netgear1_amd64.deb
# systemctl restart minidlna
Preliminary test seem good - no sign of stuttering over a range of SD and 720P video. Will test (ie watch lots of TV) over the weekend and report back. Thanks for your help!
