ReadyJabba
Feb 27, 2014Tutor
Video Stuttering / RN312 6.1.6 / Panasonic TV
Running 6.1.6 on a RN312 with DLNA and I am seeing videos pause/stutter quite regularly. Have had the same network setup with a Duo without this issue and 6.0.8 was fine on the RN312. It's not due to ...
sfigatto76
Mar 04, 2014Aspirant
Hi Everybody,
I am new here, and I am sorry if I could make mistakes or I do not follow the forum protocol exactly.
I purchased a RN10200 unit a few month ago and after some OS updates up to 6.1.6 i noted the same problem such as described in some threads.
I also noted that Mr. Skywalker solution (by the way tanks in advance by me) but I do not be able to understand what is the meaning of this
"Done.
CODE: SELECT ALL
# wget http://www.readynas.com/packages/readynasos/dists/experimental/main/pool/m/minidlna/minidlna_1.1.2~6cef303-netgear1_armel.deb
# dpkg -i minidlna_1.1.2~6cef303-netgear1_armel.deb
# systemctl restart minidlna"
Anybody could be so kindly to make me that understable? I know I'm a little dummies with this such of things.
Thank you in advance.
See you
"Done.
CODE: SELECT ALL
See you
