ReadyJabba
Feb 27, 2014Tutor
Video Stuttering / RN312 6.1.6 / Panasonic TV
Running 6.1.6 on a RN312 with DLNA and I am seeing videos pause/stutter quite regularly. Have had the same network setup with a Duo without this issue and 6.0.8 was fine on the RN312. It's not due to ...
Skywalker
Mar 04, 2014NETGEAR Expert
Those are commands that you would execute from an SSH command line. Another way to do this would be to download the package onto your PC [link], then install it using the Upload button in the Apps tab of the GUI. Note that you'd need to either reboot or disable and re-enable the ReadyDLNA service for the change to take effect.
