ReadyJabba
Feb 27, 2014Tutor
Video Stuttering / RN312 6.1.6 / Panasonic TV
Running 6.1.6 on a RN312 with DLNA and I am seeing videos pause/stutter quite regularly. Have had the same network setup with a Duo without this issue and 6.0.8 was fine on the RN312. It's not due to ...
sfigatto76
Mar 10, 2014Aspirant
Hi guys,
many thanks to skywalker. Your solution works fine.
I have been testing from last friday and it's perfect.
It solved also the usb external hard disk problem.
Back up jobs on those disks now works, before that I have had several problem.
I contacted also the netgear customer service and I explained which was the solution, I am waiting for the reply.
Thanks again Skywalker and tanks to the forum
See you
sfigatto
See you
sfigatto
