ReadyJabba
Feb 27, 2014Tutor
Video Stuttering / RN312 6.1.6 / Panasonic TV
Running 6.1.6 on a RN312 with DLNA and I am seeing videos pause/stutter quite regularly. Have had the same network setup with a Duo without this issue and 6.0.8 was fine on the RN312. It's not due to ...
ReadyJabba
Mar 13, 2014Tutor
Skywalker wrote: From the command line, the text in the parentheses I posted will do it. If you download the log .zip, it's not split out so it will be contained in systemd-journal.log.
Sorry didnt read your instructions. I see "ReadyNAS minidlnad[1778]: process.c:54: warn: Exceeded max connections [50], not forking" in the log over a period of several minutes.
