ReadyJabba
Feb 27, 2014Tutor
Video Stuttering / RN312 6.1.6 / Panasonic TV
Running 6.1.6 on a RN312 with DLNA and I am seeing videos pause/stutter quite regularly. Have had the same network setup with a Duo without this issue and 6.0.8 was fine on the RN312. It's not due to ...
ReadyJabba
Mar 23, 2014Tutor
An update;
1/ Changing max_connections didnt alleviate the issue
2/ Changing connection from Powerline ethernet over power to direct cable from the router worked - no stuttering.
Cant explain why the previous software patch change worked - likely something was coincidentally intermittently interfering with the Powerline network.
