ReadyJabba
Feb 27, 2014Tutor
Video Stuttering / RN312 6.1.6 / Panasonic TV
Running 6.1.6 on a RN312 with DLNA and I am seeing videos pause/stutter quite regularly. Have had the same network setup with a Duo without this issue and 6.0.8 was fine on the RN312. It's not due to ...
bazbrian1
Apr 01, 2014Aspirant
Skywalker wrote: Those are commands that you would execute from an SSH command line. Another way to do this would be to download the package onto your PC http://www.readynas.com/packages/readynasos/dists/experimental/main/pool/m/minidlna/minidlna_1.1.2~6cef303-netgear1_armel.deb, then install it using the Upload button in the Apps tab of the GUI. Note that you'd need to either reboot or disable and re-enable the ReadyDLNA service for the change to take effect.
I have a RN10200 firmware 6.1.6 and finding the same stuttering problem. I also have a ReadyNAS Duo 2000 firmware 4.1.13 that doesn't seem to have this problem. I have the same file on the Duo and RN10200. Both NASs are connected to the same switch that then connects to another switch in another room that has a PVR and the Panasonic TV connected. Stream the file from Duo - OK. Stream from RN10200 and sometimes get stuttering. If I pause for a few seconds, fast forward (though the "previously on ...") then press play it seems to fix it.
What exactly does the file minidlna_1.1.2~6cef303-netgear1_armel.deb do? Is this suitable for my RN10200?
I'm wondering if I made a mistake getting the RN10200, but that's what I have now.
