Chewbacca
Sep 22, 2008Aspirant
Vista Wireless Performance Questionnaire
With the amount of Vista issues on the forum, we are putting out a questionnaire here to get more information on the setups to get get a grasp of what is happening. Based on user feedback over the la...
yoh-dah
Sep 22, 2008Guide
wimski99 wrote: Just give me a few days and I'll post it for you. In the meanwhile, can you give me a short instruction on which application to use for measuring speeds?
Cheers,
Wim
Drag & drop a large file and just measure the MB/sec throughput you get both ways. That should do it.
