Chewbacca
Sep 22, 2008Aspirant
Vista Wireless Performance Questionnaire
With the amount of Vista issues on the forum, we are putting out a questionnaire here to get more information on the setups to get get a grasp of what is happening. Based on user feedback over the la...
syt
Oct 08, 2008Aspirant
Chewbacca wrote: 1) Has MTU been changed to 1492 and running Windows Vista SP1
Yes and Yes.
2) Model of Wireless Router and Firmware used.
D-Link DI-714P+ w/ firmware version 1.33 which is latest according to D-Link.
3) Wireless Card Model and Firmware
Intel 4965AGN (Don't know how to check firmware on this thing.)
4) Connection Speed that you are seeing for Wireless Adapter. (54Mbps/24Mbps)
11Mbps
5) Connection Speed between ReadyNAS to Router (10/100/1000Mbps)
100Mbps
6) Throughput from Windows XP to ReadyNAS and Vista to ReadyNAS. Both Machines at or near same location. (Read/Write MB/sec)
I don't have a Windows XP machine.
IOMeter on Vista says:
Read: 0.57 MBs per Second
Write: 0.59 MBs per Second
7) Throughput from Windows XP to Vista (Read/Write MB/sec)
8) If MTU settings were changed to 1492 on the NAS and SP1 is installed, Would like a Wireshark capture when transfering data from Vista to ReadyNAS
I have MTU set to 1492 and have installed SP1. I installed Wireshark and captured a transfer. How do I get it to you?
My answers are embedded in your quote above.
