Chewbacca
Sep 22, 2008Aspirant
Vista Wireless Performance Questionnaire
With the amount of Vista issues on the forum, we are putting out a questionnaire here to get more information on the setups to get get a grasp of what is happening. Based on user feedback over the la...
smartwombat
Nov 02, 2008Aspirant
1) Has MTU been changed to 1492 and running Windows Vista SP1
Yes
2) Model of Wireless Router and Firmware used.
wireless router Linksys WRT300N f/w 2.00.20
switch to PC HP Procurve 2900 f/w PA.02.07
3) Wireless Card Model and Firmware
Presario 1500 built-in
Broadcom 802.11 b/g (driver 4.102.15.61)
4) Connection Speed that you are seeing for Wireless Adapter. (54Mbps/24Mbps)
54Mbps
5) Connection Speed between ReadyNAS to Router (10/100/1000Mbps)
100MBps
6) Throughput from Windows XP to ReadyNAS and Vista to ReadyNAS. Both Machines at or near same location. (Read/Write MB/sec)
Vista-NAS 1.24M/s (MTU1500 33.1KB/s)
7) Throughput from Windows XP to Vista (Read/Write MB/sec)
Vista read XP 3.15MBps
Yes
54Mbps
100MBps
