Chewbacca
Sep 22, 2008Aspirant
Vista Wireless Performance Questionnaire
With the amount of Vista issues on the forum, we are putting out a questionnaire here to get more information on the setups to get get a grasp of what is happening. Based on user feedback over the la...
Jellen
Nov 07, 2008Aspirant
My Wireless problems are fixed when I change Readynas Duo to 1492 but then my wired gigabit clients slow down by an average of 50% Is this normal?
1) Has MTU been changed to 1492 and running Windows Vista SP1
Yes
2) Model of Wireless Router and Firmware used.
D-Link DGL-4300 FW. 1.9 (latest) also tested with 1.7 (no difference)
3) Wireless Card Model and Firmware
Intel Wifi 5100 AGN driver 12.1.0.14
4) Connection Speed that you are seeing for Wireless Adapter. (54Mbps/24Mbps)
54 Mbps
5) Connection Speed between ReadyNAS to Router (10/100/1000Mbps)
1000Mbps
6) Throughput from Windows XP to ReadyNAS and Vista to ReadyNAS. Both Machines at or near same location. (Read/Write MB/sec)
XP up and download 2.5MiB/sec
Vista up and download freezes or averages around 10Kib/sec When I change to MTU 1942 Everything fine and 2.5MiB/sec
7) Throughput from Windows XP to Vista (Read/Write MB/sec)
From wired XP to wireless Vista up and download 2.5MiB/sec
Wired XP and Vista performance drops from 25MiB/sec download to 11MiB/sec when I change MTU to 1942
Don't want to suffer freezes and slow transfer rates on my Vista wireless but also need the full speed to my wired installation.
If you need more information to solve this I always want to do more testing...
Kind regards
Jellen
UPDATE: Also forgot to mention that I connected my Readynas to Vista and XP machine and still got a max read speed of 11MiB/sec when I change MTU to 1492, tried with other utp cable too
Yes
54 Mbps
1000Mbps
Kind regards
Jellen
