Chewbacca
Sep 22, 2008Aspirant
Vista Wireless Performance Questionnaire
With the amount of Vista issues on the forum, we are putting out a questionnaire here to get more information on the setups to get get a grasp of what is happening. Based on user feedback over the la...
cfish
Nov 20, 2008Aspirant
yoh-dah wrote: Try lowering MTU only on the client that you access over wireless. This will force the ReadyNAS MTU down to 1492 only with the wireless client.
OK, I used this very useful tutorial http://www.kitz.co.uk/adsl/vistaMTU.htm to set the MTU on my Vista wireless laptop to 1492. I then set the NAS MTU back to 1500. Result: wired speed back to normal, wireless is now unusable again. So, setting the MTU on the wireless laptop to 1492 makes no difference. The only thing that seems to work is changing the MTU on the NAS thus halving the wired transfer rate. :(
