Chewbacca
Sep 22, 2008Aspirant
Vista Wireless Performance Questionnaire
With the amount of Vista issues on the forum, we are putting out a questionnaire here to get more information on the setups to get get a grasp of what is happening. Based on user feedback over the la...
Jellen
Dec 05, 2008Aspirant
yoh-dah wrote: We're trying to come up with a solution where you can specify in FrontView the systems where burst mode should be disabled (equiv to setting MTU to 1492), allowing normal wired systems to enjoy the faster burst mode. We'll have a beta for that hopefully in a couple weeks.
Ok I'll be the first one to test the new beta, can always pm me if you want me to test something...
Hope this solves the problem then.
Keep up the good work jedi's !
Kind regards
Jellen
