Chewbacca
Sep 22, 2008Aspirant
Vista Wireless Performance Questionnaire
With the amount of Vista issues on the forum, we are putting out a questionnaire here to get more information on the setups to get get a grasp of what is happening. Based on user feedback over the la...
daveP1
Jan 02, 2009Aspirant
kiki wrote: Hi Chewbacca,
I would just confirm that all Vista related performance issues were solved on my Notebook after I changed the NetworkThrottlingIndex registry key value to 70 (Decimal)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Multimedia\SystemProfile\
As described here:
http://support.microsoft.com/default.aspx/kb/948066
Can you provide further information? I'm having lots of performance and reliability issues with my wireless-N connection. I am also having performance issues w/ my wired connection. Both are Vista. (For further information, you can read my posting on 1 Jan 2008.)
I read the Microsoft help and support topic that you mentioned. It seems that it applies to the situation where there are multiple streams of data and at least some are time-sensitive. This doesn't describe the situation that I'm struggling with, though. Still, if you've got a solution that would help me, I would like to understand it.
In advance, thanks.
