Chewbacca
Sep 22, 2008Aspirant
Vista Wireless Performance Questionnaire
With the amount of Vista issues on the forum, we are putting out a questionnaire here to get more information on the setups to get get a grasp of what is happening. Based on user feedback over the la...
Matt_Harman
Jan 13, 2009Aspirant
Hi there, I've had a ReadyNas Duo about 3-4 months and it's worked fine out of the box. However I just bought a new laptop and had to have vista on it rather than xp :(. The ReadyNas works fine from my xp laptop, but runs like I'm on a dial up connection from vista making it pretty unusable. I've down loaded theIOmeter and readynas test file and this confirms my problems.
There is a lot of information in this thread about tweaking vista and a ReadyNas, I guess I'm after a tip of where to start....
I'll look to get more detailed info up, but I've got a ReadyNas Duo with 2 x 750GB disk RAIDed -- 100mb duplex lan connection to a netgear Rangemax router. I've connected my vista laptop with a 54Mbps wireless link. I'm not expecting stella performance with this setup, but I'd hope to crack the 1MBs transfer rate. when I look at the outputs from IOmeter, the latency look pretty hi (average 218ms, max 1816ms) and I'm getting a sub 1MBs transfer rate
thanks for any pointers!
Matt.
Matt.
