Chewbacca
Sep 22, 2008Aspirant
Vista Wireless Performance Questionnaire
With the amount of Vista issues on the forum, we are putting out a questionnaire here to get more information on the setups to get get a grasp of what is happening. Based on user feedback over the la...
Jellen
Jan 16, 2009Aspirant
ken830 wrote: I've been experiencing the same thing since owning a ReadyNAS (for the past 6-7 months). It's driving me nuts! The MTU workaround is not acceptable because it greatly affects the wired performance, which I depend on for backups and large transfers... But wireless on Vista is completely unusable right now...
I have found a temporary solution!
Change the MTU setting on your Vista wireless card to 1460 via this method: http://www.kitz.co.uk/adsl/vistaMTU.htm Wireless performance on Vista is great, at least on my G network at home.
Leave the Readynas at it's default 1500 so that wired transfers maintain their performance.
Report back if this works out for you.
Kind regards
Jellen
