Chewbacca
Sep 22, 2008Aspirant
Vista Wireless Performance Questionnaire
With the amount of Vista issues on the forum, we are putting out a questionnaire here to get more information on the setups to get get a grasp of what is happening. Based on user feedback over the la...
gpvillamil
Feb 28, 2009Aspirant
For what it's worth, all my problems disappeared after changing the router on my network.
I replaced the combo of Linksys WRT54GS + NetGear GigE switch with a D-Link DIR655, enabled jumbo frames (MTU jumped automatically) and now I get:
Vista wireless, read & write: 4.1MB/s (32 mbps)
XP wired, read & write: 17MB/s (136 mbps)
I have not yet tweaked journalling settings on the ReadyNAS, so might get some further boosts once I do that.
gpvillamil wrote: 1) Has MTU been changed to 1492 and running Windows Vista SP1
Yes. Disabled Jumbo Frames on the NAS and set MTU to 1492. Also set MTU on the router to 1492.
2) Model of Wireless Router and Firmware used.
Linksys WRT54GS, v4.71.4
3) Wireless Card Model and Firmware
Intel 4965 AGN, 12.0.0.82
4) Connection Speed that you are seeing for Wireless Adapter. (54Mbps/24Mbps)
54 mbps
5) Connection Speed between ReadyNAS to Router (10/100/1000Mbps)
100 mbps
6) Throughput from Windows XP to ReadyNAS and Vista to ReadyNAS. Both Machines at or near same location. (Read/Write MB/sec)
Vista - read from ReadyNAS 1.3MB/sec
Vista - write to ReadyNAS 1.0MB/sec
XP - read from ReadyNAS 1.0MB/sec
XP - write to ReadyNAS 1.0MB/sec
The XP performance seems a lot slower than I remember.
7) Throughput from Windows XP to Vista (Read/Write MB/sec)
n/a don't have any XP shares visible to Vista
8) If MTU settings were changed to 1492 and SP1 is installed, Would like a Wireshark capture when transfering data from Vista to ReadyNAS
Notes: I have done all of the following:
1. disabled Vista's multimedia throttling via registry tweak.
2. disabled Vista auto-tuning (via netsh command)
3. disabled Vista firewall when on local network
