Chewbacca
Sep 22, 2008Aspirant
Vista Wireless Performance Questionnaire
With the amount of Vista issues on the forum, we are putting out a questionnaire here to get more information on the setups to get get a grasp of what is happening. Based on user feedback over the la...
anhlai
Mar 06, 2009Aspirant
Searching the Internet about Vista's generally slow network share access, this is all I did and wham, Vista is fast. Left my router/readynas settings alone.
Disabling Remote Differential Compression. To do this:
Open Control
Panel>Add Remove Programs>Turn off Windows features, uncheck Remote
Disable auto tuning:
From Command Promp, run as Administrator type: netsh int tcp set global autotuninglevel=disabled
Open Control
