Chewbacca
Sep 22, 2008Aspirant
Vista Wireless Performance Questionnaire
With the amount of Vista issues on the forum, we are putting out a questionnaire here to get more information on the setups to get get a grasp of what is happening. Based on user feedback over the la...
CheapNAS
Apr 23, 2009Aspirant
Hi,
My questionnaire is below, and the suggested tips didn't work, but I found something that does:
In 4.1.4, lowering the MTU on the ReadyNAS to 1492 sped up wireless. In 4.1.5, this does not help. I then raised the 4.1.5 MTU back up to 1500, and I lowered the MTU on the Vista wireless to 1492 and that didn't help. So I tried lowering it even more to 1430, and the speed jumped up. Now it's at ~1.8MB/s. Then I just slowly tweaked up the MTU -- it's now at 1450. Still a bit slower, but at least it's usable.
So glad everything is usable!
Chewbacca wrote:
0) Updated to Windows Vista SP1? SP1 contains a number of network changes that improved overall throughput with the ReadyNAS.
Yes.
1) Tried changing MTU on ReadyNAS and laptop to 1492? Instructions on how to change Vista MTU at http://www.kitz.co.uk/adsl/vistaMTU.htm . A couple users had success keeping the ReadyNAS MTU at 1500 and switching Vista MTU to 1460.
Yes, did not help.
2) What model of Wireless Router and firmware is being used?
Buffalo 54G, DD-WRT 24sp1
3) What Wireless Card model and firmware being used?
Intel 4965agn, unknown.
4) What connection speed are you seeing for Wireless Adapter (i.e. 54 Mbps)?
5-500KB/s
5) What's the connection speed between ReadyNAS to Router (10/100/1000 Mbps) -- you can see this in FrontView's Network page.
100 Full Duplex
6) What's the throughput from Windows XP to ReadyNAS and Vista to ReadyNAS? Both Machines at or near same location?
No XP machine
Vista: ~9MB/s
7) Whats the throughput from Windows XP to Vista?
No XP machine
8) Does disabling firewall help? One user reported problem solved by disabling Symantec firewall.
None installed.
9) Does uninstalling anti-virus help? One user reported problem solved by uninstalling CA anti-virus.
Disabled, and did not help.
10) Does enabling jumbo frames work? Several folks reported problem solved by enabling jumbo frames, and this also had the effect of speeding up wired transfers.
No.
11) Are you able to try another router? A couple users reported replacing current router/switch solved the problem.
No.
