Chewbacca
Sep 22, 2008Aspirant
Vista Wireless Performance Questionnaire
With the amount of Vista issues on the forum, we are putting out a questionnaire here to get more information on the setups to get get a grasp of what is happening. Based on user feedback over the la...
RobbieTT
May 05, 2009Tutor
0) Updated to Windows Vista SP1? SP1 contains a number of network changes that improved overall throughput with the ReadyNAS.
ANS: Windows Home Vista Premium SP1 Laptop using 32bit.
1) Tried changing MTU on ReadyNAS and laptop to 1492? Instructions on how to change Vista MTU at http://www.kitz.co.uk/adsl/vistaMTU.htm . A couple users had success keeping the ReadyNAS MTU at 1500 and switching Vista MTU to 1460.
ANS: All systems on network were set at MTU = 1500. Setting Sony TX5 Vista laptop to 1460 fixed my problem. Tried 1492 and it seemed as bad as 1500.
2) What model of Wireless Router and firmware is being used?
ANS: BT HomeHub V1 6.2.6.H
3) What Wireless Card model and firmware being used?
ANS: Intel PRO/Wireless 3945ABG Driver 10.6.0.29
4) What connection speed are you seeing for Wireless Adapter (i.e. 54 Mbps)?
ANS: 54 Mbps
5) What's the connection speed between ReadyNAS to Router (10/100/1000 Mbps) -- you can see this in FrontView's Network page.
ANS: 1000 Mbps
6) What's the throughput from Vista to ReadyNAS? Both Machines at or near same location?
ANS: Wired through above router. NAS-> Vista 32bit = 5.8 MB/sec average, peak = 6.92 MB/sec
7) Whats the throughput to Vista?
ANS: Vista wireless MTU = 1460 2.3 MB/sec average, peak=2.89 MB/sec
Does disabling firewall help? One user reported problem solved by disabling Symantec firewall.
ANS: Didn't try
9) Does uninstalling anti-virus help? One user reported problem solved by uninstalling CA anti-virus.
ANS: Didn't try
10) Does enabling jumbo frames work? Several folks reported problem solved by enabling jumbo frames, and this also had the effect of speeding up wired transfers.
ANS: Didn't Try
11) Are you able to try another router? A couple users reported replacing current router/switch solved the problem.
ANS: Didn't try
ANS: 54 Mbps
ANS: 1000 Mbps
ANS: Didn't try
ANS: Didn't try
ANS: Didn't Try
ANS: Didn't try
