Chewbacca
Sep 22, 2008Aspirant
Vista Wireless Performance Questionnaire
With the amount of Vista issues on the forum, we are putting out a questionnaire here to get more information on the setups to get get a grasp of what is happening. Based on user feedback over the la...
rdouven
Jun 14, 2009Aspirant
have you also tried the below because it's more then just MTU that vista fouls up.
I've had all the same issues and have it now tweaked to the right settings. The following link provided me with the right information:
http://www.kitz.co.uk/adsl/vistaTCPtweaks.htm
I've got the following settings:
C:\Windows\system32>netsh interface tcp show global
Querying active state...
TCP Global Parameters
Receive-Side Scaling State : enabled
Chimney Offload State : enabled
Receive Window Auto-Tuning Level : normal
Add-On Congestion Control Provider : ctcp
ECN Capability : enabled
RFC 1323 Timestamps : disabled
