Chewbacca
Sep 22, 2008Aspirant
Vista Wireless Performance Questionnaire
With the amount of Vista issues on the forum, we are putting out a questionnaire here to get more information on the setups to get get a grasp of what is happening. Based on user feedback over the la...
mvarga99
Jun 18, 2009Aspirant
Extremely frustrated with the inability to use my Vista laptop with wireless connection to access the ReadyNAS Duo. I use a Netgear router and have Comcast high speed internet. Looks like many others are having the same problem.
Before purchasing the Duo, I had a network drive for 3 years hooked up to the same network with the same computers. It worked great until the drive burned out or something.
After shopping for a new network drive, I decided to buy the ReadyNAS and I made sure to ask if it was compatible with Vista.
I'm not familiar with how to make all these network adjustments and registry modifications that I'm reading about. Just want the machine to work as advertised. Best Buy won't take it back now and I'm stuck with this machine that does not work.
Is there a fix coming???
