Chewbacca
Sep 22, 2008Aspirant
Vista Wireless Performance Questionnaire
With the amount of Vista issues on the forum, we are putting out a questionnaire here to get more information on the setups to get get a grasp of what is happening. Based on user feedback over the la...
s0828
Mar 12, 2010Aspirant
I'm getting poor performance with Windows Vista SP2 and ReadyNAS Duo. My ReadyNAS Duo has firmware: RAIDiator 4.1.6 [1.00a043].
SP2
I have tried and it is still slow.
netgear router DG834G V4.01.40
built in Intel wireless wifi link 5100
54 Mbps
100
My home computers: Sony Vaio laptop with windows vista home premium SP2; apple powerbook macos 10.6, fujitsu siemens laptop windows XP home.
OK
No
No, but I try only to disable Norton antyvirus.
Doesn't help :(
I will try...
0) Updated to Windows Vista SP1? SP1 contains a number of network changes that improved overall throughput with the ReadyNAS.
SP2
1) Tried changing MTU on ReadyNAS and laptop to 1492? Instructions on how to change Vista MTU at http://www.kitz.co.uk/adsl/vistaMTU.htm . A couple users had success keeping the ReadyNAS MTU at 1500 and switching Vista MTU to 1460.
2) What model of Wireless Router and firmware is being used?
3) What Wireless Card model and firmware being used?
4) What connection speed are you seeing for Wireless Adapter (i.e. 54 Mbps)?
54 Mbps
5) What's the connection speed between ReadyNAS to Router (10/100/1000 Mbps) -- you can see this in FrontView's Network page.
100
6) What's the throughput from Windows XP to ReadyNAS and Vista to ReadyNAS? Both Machines at or near same location?
7) Whats the throughput from Windows XP to Vista?
OK
8) Does disabling firewall help? One user reported problem solved by disabling Symantec firewall.
No
9) Does uninstalling anti-virus help? One user reported problem solved by uninstalling CA anti-virus.
10) Does enabling jumbo frames work? Several folks reported problem solved by enabling jumbo frames, and this also had the effect of speeding up wired transfers.
Doesn't help :(
11) Are you able to try another router? A couple users reported replacing current router/switch solved the problem.
I will try...
