Tom_at_Neat
Dec 06, 2011Aspirant
VMware ESXi4.1 ISCSI Readynas 3200 - need more...
I have what would be considered average and expected performance with our HP DL360 G7 ESXi 4.1u2 servers using ISCSI to connect to our ReadyNAS 3200 (4.2.19) in RAID10. Running Crystal Disk Mark v....
chirpa
Dec 06, 2011Luminary
You can add an additional (2) 1Gbe ports with an add-on card. (viewtopic.php?p=185200#p185200)
Does your switch support LACP or other teaming/bonding modes? You can bond the NICs together to obtain a higher throughput. You can use iSCSI and web management on the same NICs, don't need one NIC dedicated to management.
