scott_mac
Aug 31, 2011Aspirant
VMWare iSCSI Dropouts
Hi Folks, I've had a search and found a similar issue to what we're having but can't seem to find a definitive solution.... basically i'm having similar issues to this thread: http://www.readynas.c...
jeremyotten
Mar 11, 2012Aspirant
You should disable chap authentication and just use iscsi initiator security. Then it will all be solved!
