scott_mac
Aug 31, 2011Aspirant
VMWare iSCSI Dropouts
Hi Folks, I've had a search and found a similar issue to what we're having but can't seem to find a definitive solution.... basically i'm having similar issues to this thread: http://www.readynas.c...
gavind
May 17, 2013Aspirant
looneyM wrote: I opened a case this morning for the same issue. I do not see anything in the esxi hosts but I did see a bunch of release messages every 5 seconds in the log of the readynas. I have been having this issue since I installed the unit one month ago. Oddly I am only having a serious issue (total disconnect) on Fridays between 12:00 - 1:00 EST. The tech support agent today had me use the same time servers(factory setting is use netgears time servers) as the esxi hosts and we turned off Auto update checking feature. I will post back Friday with results. Netgear I hope you are listening I have purchased 4 of these for my customers and one will be installed this friday for a production enviornment.
Hi Looeny, got any updates on this so far? Not sure if upgrading helped here.
