AndreasLi
Jul 15, 2020Aspirant
'Volume creation failed' for the second hard drive in ReadyNAS 102, please help
I just bought the 2nd HDD, a WD red pro 6TB, to expand space for my RN102. I tried to format it and make it into a new volume, but it always says: 'Volume creation failed'. The error info are attach...
Jul 15, 2020Guru - Experienced User
AndreasLi wrote:
I found out the 1st disk, a 3TB WD red HDD, was configured as RAID1, and guess this might be the problem.
No. That's confusing, but actually normal.
Can you test the new disk with WD's Lifeguard software in a Windows PC? You can connect it with a USB adapter/dock if you can't use SATA.
AndreasLi
Jul 16, 2020Aspirant
I put it in a HDD Enclosure and start the diagnostics. It just beeping constantly... I remember when I put it in the NAS, it also beeped for a few seconds.
Then it seems an issue on the HDD itself. I'm now checking how can I return it to WD now :(
- StephenBJul 16, 2020Guru - Experienced User
Definitely the drive then.
Exchange it with the seller if you can, they should give you a new drivewith a full warranty in return. WD will give you a recertified one (with only a one year warranty).
