lorenz
Jan 27, 2019Aspirant
volume degraded after disk swap on a RN312
Hi there,
I run a RN312 with two 6TB western digital red drives runing x-raid. one of them started having an increasing reallocated sector count, so I replaced it with another drive of the same...
- Feb 02, 2019
that's right, I did replace it with one of the same type and size...
I did a factory reset and the volume ist healthy again now, "just" need to restore the back up after updating the ssh setup with the newly generated keys....ah well....
thanks for thinking along sandshark & stephenB!
best,
Lorenz
lorenz
Jan 29, 2019Aspirant
thanks a lot for the ideas stephen! I did as you suggested: data was still there after removing the new disk that was only recognized as spare. re-wrote it will all zeros. powered down the RN, reinserted the wiped disk, powered it up again, it synced: same result - volume is still degraded..:-(
on the up side I now have a hard drive docking station to wipe and re-use my old drives..;-)...
I just realized I did deviate from your suggestion in one point: I did not hot-insert the wiped drive as that did not work the 1st time. could that make a difference? if not: any other ideas?
thanks & best,
lorenz
Jan 29, 2019Guru - Experienced User
Hot-insertion is better because the NAS detects the insertion. If you insert with the NAS powered down, it needs to figure out that an insertion was done.
The net here though is that the NAS is insisting on marking the drive as a spare. One thing you could try (painful) is to do a factory reset with both drives in place. After a successful RAID sync you'd have to restore the data from backup.
You could also try paid support via my.netgear.com.
- lorenzJan 30, 2019Aspirant
hot insertion did not help either. will backup my config and try moving from x-raid to flex-raid and report back if that makes the RN include the 2nd disk again. if I do not report back on this thread again, I will have resorted to going back to factory settings...:-/
thanks for attempting to help!
cheers,
lorenz
- SandsharkJan 31, 2019Sensei
I believe you should be able to change to FlexRAID and manually add the drive to your array with the "expand" option, then move back to XRAID once it's complete. You may have to re-format the drive first (in the NAS).
- lorenzJan 31, 2019Aspirant
thanks, that was my idea as well, however when moving to flexraid the volume is shown as raid 1, however still degraded. I can thus not proceed as planned / as suggested.
also any reboot results in a re-sync of the 2nd drive, regardless wether in X-Raid or flexraid, but always with the same result - a degraded volume.
overall this might be a bug in the drive detection / raid software as it originally occured after hot swapping the failing drive for a new one. will likely restore factory settings over the weekend...
