Damia
Mar 28, 2016Guide
volume disk test
Mon Mar 28 2016 8:53:34 Volume: Disk test failed on disk in channel 1, model , serial . Mon Mar 28 2016 4:00:12 Volume: Disk test started for volume data my question is- is this mea...
- Mar 29, 2016
i have consulted with Tech Support
looks like replacement needed
NETGEAR Level 2 Support.
I have reviewed the information from the system logs of your NAS. It seems like disk 1 on your NAS has 43 reallocated sectors. The usual threshold is about 100 but it would be better that you back up the data on your drive 1. Your drive might fail in any moment so it would be better to replace it now with a healthy drive. Since you have RAID 1 setup, the new drive replacement should automatically sync with your current volume once you insert it
Mar 28, 2016Guru - Experienced User
Click on the settings wheel next to the volume (on the volume tab).
I don't think you will see "disk test". But if you click on "volume schedule" you can schedule one.
Damia
Mar 28, 2016Guide
This is what i did on the first place that's where i got this error
- DamiaMar 29, 2016Guide
I have reviewed the information from the system logs of your NAS. It seems like disk 1 on your NAS has 43 reallocated sectors. The usual threshold is about 100 but it would be better that you back up the data on your drive 1. Your drive might fail in any moment so it would be better to replace it now with a healthy drive. Since you have RAID 1 setup, the new drive replacement should automatically sync with your current volume once you insert it - DamiaMar 29, 2016Guide
thx for helping
