mattjam
Mar 26, 2019Follower
Volume is read-only
Hi,
I have a ReadyNAS102 and the volume is read only. I can't access any data from shares, only from the GUI. Version is 6.9.4 Hotfix1.
According to log from GUI : "Volume: The volume data encountered an error and was made read-only. It is recommended to backup your data."
Go deeper in dmesg :
Tue Mar 26 22:30:41 2019] md/raid1:md127: active with 2 out of 2 mirrors
[Tue Mar 26 22:30:41 2019] md127: detected capacity change from 0 to 3995818786816
[Tue Mar 26 22:30:41 2019] BTRFS: device label 0e36975f:data devid 1 transid 601721 /dev/md127
[Tue Mar 26 22:30:41 2019] Adding 523708k swap on /dev/md1. Priority:-1 extents:1 across:523708k
[Tue Mar 26 22:30:47 2019] BTRFS error (device md127): qgroup generation mismatch, marked as inconsistent
[Tue Mar 26 22:30:47 2019] BTRFS info (device md127): checking UUID tree
[Tue Mar 26 22:30:50 2019] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[Tue Mar 26 22:30:55 2019] mvneta d0074000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[Tue Mar 26 22:30:55 2019] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[Tue Mar 26 22:31:25 2019] BTRFS error (device md127): parent transid verify failed on 522387456 wanted 601651 found 601714
[Tue Mar 26 22:31:25 2019] BTRFS warning (device md127): Skipping commit of aborted transaction.
[Tue Mar 26 22:31:25 2019] BTRFS: error (device md127) in cleanup_transaction:1864: errno=-5 IO failure
[Tue Mar 26 22:31:25 2019] BTRFS info (device md127): forced readonly
[Tue Mar 26 22:31:25 2019] BTRFS info (device md127): delayed_refs has NO entry
Is there any tool I could launch to fix this and get back my device running ?
Thanks for help.
1 Reply
- Marc_VNETGEAR Employee Retired
Hi mattjam
Welcome to the Community!
Have you tried rebooting the NAS? It might be best if you do a full backup of your data using the GUI or if you can access the shares.
This might need escalation since there are BTRFS errors and data is involved but if you have backup, doing a Factory reset is also an option.
You may want to contact Support for assistance on escalating a case.
Hope this helps!
Regards
