Markuzz
Jun 25, 2023Aspirant
Volume lost on ReadyNas 104
Hello, I lost my volume on a ReadyNas 104. No errors have been logged according to the admin page, only a bunch of warnings around April this year. See output in attachment. I have not done a...
- Jun 27, 2023
Markuzz wrote:
See attachment for output 1 of 2.
This should assemble, so I am puzzled by the earlier issue.
The event counters (13922, 13917, 13926, 13917) do show some lost writes - they should all be 13926.
Maybe try this variation:
mdadm --assemble --really-force /dev/md127 /dev/sda3 /dev/sdb3 /dev/sdc3 /dev/sdd3
Markuzz
Jun 26, 2023Aspirant
Hi schumaku,
Thanks for your swift reply.
I do not understand - while having a few warnings - the volume gets lost. Also the NAS is currently reporting all disks are healthy (except there is no active volume).
Is there anyway to try force connect the volume again?
Cheers, Mark.
Jun 26, 2023Guru - Experienced User
In February, the volume became degraded - meaning one disk dropped out of the array. The screenshot doesn't say which one.
Later on we see warnings that two additional disks were failing. Also that a third disk was removed.
All of these can (and often do) lead to data loss.
But we are only seeing the warnings in your screen shot, and there is lot of info that is likely missing. For instance, it is possible that the volume resynced after the February problem. Also we don't know what RAID mode you are using.
Probably the best path is RAID recovery software (ReclaiMe is one people have used here). You'd need a way to connect the disks to a Windows PC (usb adapter docks will work, some have multiple bays). And you'd need a place to offload the data.
It might be possible to forcibly assemble the array - not sure. I wouldn't put much stock in the disk health you are seeing now. Have you ever used the linux command line? Also is ssh already enabled on the NAS.
- MarkuzzJun 26, 2023Aspirant
Hi StephenB,
Many thanks for your reply.
I've copied the status.log with the warnings hereunder. I have not removed any disks in the last years.
The NAS is in X-Raid mode. Also I 'suddenly' noticed that the volume seems to be there, but inactive. See attachment.
I am familiar with ssh and the command line. So any help as to try to reconnect the volume via a terminal is highly appreciated!
Kind regards,
Mark
-- STATUS.LOG
[23/02/12 14:05:43 CET] warning:disk:LOGMSG_DELETE_DISK Disk Model:Hitachi HDS5C3030ALA630 Serial:MJ1311YNG6YY5A was removed from Channel 4 of the head unit.
[23/02/12 14:05:45 CET] warning:volume:LOGMSG_HEALTH_VOLUME Volume MusicDrive health changed from Redundant to Degraded.
[23/02/12 14:13:21 CET] info:system:LOGMSG_READYNASD_ABORTED_NOINFO ReadyNASOS service or process was restarted.
[23/02/12 14:13:26 CET] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume MusicDrive is Degraded.
[23/02/12 14:13:26 CET] warning:system:LOGMSG_SENT_ALERT_MESG_FAILED Alert message failed to send.
[23/02/12 14:13:34 CET] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[23/02/12 14:13:38 CET] warning:system:LOGMSG_BOND_NETWORK_SLAVE_NIC_DOWN Bond interface bond0 has slave interface eth1 offline.
[23/02/12 14:13:53 CET] notice:volume:LOGMSG_RESILVERSTARTED_VOLUME Resyncing started for Volume MusicDrive.
[23/02/12 14:14:36 CET] warning:volume:LOGMSG_READYTIER_REPLACE_MIXED_DISK It is not recommended to mix different disk types. Current volume is using SATA 7200 RPM drives. Please replace the disk in channel 4 (Internal) to match the rest of the disks on volume MusicDrive for best performance.
[23/02/12 15:32:39 CET] warning:volume:LOGMSG_READYTIER_REPLACE_MIXED_DISK It is not recommended to mix different disk types. Current volume is using SATA 7200 RPM drives. Please replace the disk in channel 4 (Internal) to match the rest of the disks on volume MusicDrive for best performance.
[23/02/13 01:00:54 CET] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume MusicDrive is Degraded.
[23/02/14 01:00:28 CET] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume MusicDrive is Degraded.
[23/02/15 01:00:28 CET] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume MusicDrive is Degraded.
[23/02/15 13:03:33 CET] notice:volume:LOGMSG_RESILVERCOMPLETE_VOLUME Volume MusicDrive is resynced.
[23/02/15 13:03:34 CET] notice:volume:LOGMSG_HEALTH_VOLUME Volume MusicDrive health changed from Degraded to Redundant.
[23/02/15 13:03:34 CET] notice:disk:LOGMSG_ZFS_DISK_STATUS_CHANGED Disk in channel 4 (Internal) changed state from RESYNC to ONLINE.
[23/02/16 08:18:35 CET] notice:system:LOGMSG_SYSTEM_HALT The system is shutting down.
[23/03/16 08:20:45 CET] warning:disk:LOGMSG_SMART_SPIN_RETRY_WARN Detected high spin retry count: [131073] on disk 2 (Internal) [TOSHIBA DT01ACA300, Y3RDZRKGS]. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
[23/03/16 08:20:48 CET] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[23/03/16 08:20:45 CET] warning:system:LOGMSG_SENT_ALERT_MESG_FAILED Alert message failed to send.
[23/03/16 08:21:03 CET] warning:system:LOGMSG_BOND_NETWORK_SLAVE_NIC_DOWN Bond interface bond0 has slave interface eth1 offline.
[23/03/16 11:46:49 CET] notice:system:LOGMSG_SYSTEM_HALT The system is shutting down.
[23/04/16 12:48:51 CEST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[23/04/16 12:49:00 CEST] warning:system:LOGMSG_BOND_NETWORK_SLAVE_NIC_DOWN Bond interface bond0 has slave interface eth1 offline.
[23/04/16 12:49:00 CEST] warning:system:LOGMSG_SENT_ALERT_MESG_FAILED Alert message failed to send.
[23/04/17 08:16:48 CEST] info:system:LOGMSG_READYNASD_ABORTED_NOINFO ReadyNASOS service or process was restarted.
[23/04/17 08:16:53 CEST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[23/04/17 08:17:01 CEST] warning:system:LOGMSG_BOND_NETWORK_SLAVE_NIC_DOWN Bond interface bond0 has slave interface eth1 offline.
[23/04/17 08:17:01 CEST] warning:system:LOGMSG_SENT_ALERT_MESG_FAILED Alert message failed to send.
[23/04/20 00:33:07 CEST] info:system:LOGMSG_READYNASD_ABORTED_NOINFO ReadyNASOS service or process was restarted.
[23/04/20 00:33:13 CEST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[23/04/20 00:33:21 CEST] warning:system:LOGMSG_BOND_NETWORK_SLAVE_NIC_DOWN Bond interface bond0 has slave interface eth1 offline.
[23/04/20 00:33:21 CEST] warning:system:LOGMSG_SENT_ALERT_MESG_FAILED Alert message failed to send.
[23/04/20 00:49:25 CEST] warning:disk:LOGMSG_DELETE_DISK Disk Model:ST3000DM001-1CH166 Serial:Z1F47LTW was removed from Channel 1 of the head unit.
[23/04/20 00:49:25 CEST] warning:volume:LOGMSG_HEALTH_VOLUME Volume MusicDrive health changed from Redundant to Dead.
[23/04/20 00:49:27 CEST] warning:disk:LOGMSG_DELETE_DISK Disk Model:ST3000DM001-1CH166 Serial:Z1F4C9PX was removed from Channel 3 of the head unit.
[23/04/20 00:49:29 CEST] notice:disk:LOGMSG_ADD_DISK Disk Model:ST3000DM001-1CH166 Serial:Z1F47LTW was added to Channel 1 of the head unit.
[23/04/20 00:49:36 CEST] notice:disk:LOGMSG_ADD_DISK Disk Model:ST3000DM001-1CH166 Serial:Z1F4C9PX was added to Channel 3 of the head unit.
[23/04/20 00:51:11 CEST] notice:disk:LOGMSG_ZFS_DISK_STATUS_CHANGED Disk in channel 1 (Internal) changed state from RESYNC to ONLINE.
[23/04/20 00:52:55 CEST] notice:disk:LOGMSG_ZFS_DISK_STATUS_CHANGED Disk in channel 3 (Internal) changed state from RESYNC to ONLINE.
[23/04/20 01:00:28 CEST] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume MusicDrive is Dead.
[23/04/20 01:13:18 CEST] warning:disk:LOGMSG_SMART_SPIN_RETRY_WARN Detected high spin retry count: [327682] on disk 4 (Internal) [Hitachi HDS5C3030ALA630, MJ1311YNG6YY5A]. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
[23/04/20 01:15:09 CEST] warning:disk:LOGMSG_DELETE_DISK Disk Model:Hitachi HDS5C3030ALA630 Serial:MJ1311YNG6YY5A was removed from Channel 4 of the head unit.
[23/04/20 01:15:21 CEST] warning:disk:LOGMSG_SMART_SPIN_RETRY_WARN Detected high spin retry count: [1245187] on disk 2 (Internal) [TOSHIBA DT01ACA300, Y3RDZRKGS]. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
[23/04/20 05:34:22 CEST] notice:system:LOGMSG_SYSTEM_HALT The system is shutting down.- StephenBJun 26, 2023Guru - Experienced User
[23/04/20 01:00:28 CEST] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume MusicDrive is Dead.A little odd, since the volume name for X-RAID is always "data", and yours is "MusicDrive". So you must have started out in FlexRAID, and then switched before you did any expansion.
Is ssh enabled on the NAS? If it isn't then you'll need to boot into tech support mode and connect with telnet. We can give more detailed instructions if needed.
Given the dicey situation with the disks, I'd begin with running full non-destructive tests with smartctl, and then attempt to assemble/remount the volume. If successful, I strongly recommend that you back up the data before doing anything else.
- SandsharkJun 26, 2023Sensei
Your problem may be power related -- not enough to spin the drives up properly. It could be the power brick or something internal to the NAS.
The best next step is to test the two "bad" drives in a PC with the drive vendor's tools. If they actually pass (except for the existing SMART errors), then that adds evidence that that is the issue.
BTW, you have your alert email set up wrong, which is why you didn't get any email warnings about this.
