tyrrminal
Jul 21, 2023Aspirant
Volume missing following crash and rebuild
ReadyNAS NV+ v2 running RAIDiator 5.3.12 When I woke up this morning I found that my NAS was turned off. I turned it back on and it immediately started an array rebuild (4x3 TB Toshiba disks, X-R...
Jul 22, 2023Guru - Experienced User
When I woke up this morning I found that my NAS was turned off. I turned it back on and it immediately started an array rebuild (4x3 TB Toshiba disks, X-RAID). While it was rebuilding, I was able to view and access files on the NAS throughout the day (the rebuild took around 14 hours).
When the rebuild completed, I tried to access my files and received errors, so I rebooted the device. Once it came back up, it no longer shows my volume from the array, although it shows all disks as healthy. I suspect/hope that the data is intact, but the device just has become unconfigured for accessing it. I have ssh access, but I need guidance for how to go about recovering this.
Have you downloaded the full log zip file? There are likely more clues in the logs.
- tyrrminalJul 22, 2023Aspirant
The Logs section of the Dashboard just says "No Logs" and the Download Logs button does nothing
