tyrrminal
Jul 21, 2023Aspirant
Volume missing following crash and rebuild
ReadyNAS NV+ v2 running RAIDiator 5.3.12 When I woke up this morning I found that my NAS was turned off. I turned it back on and it immediately started an array rebuild (4x3 TB Toshiba disks, X-R...
Jul 22, 2023Guru - Experienced User
When I woke up this morning I found that my NAS was turned off. I turned it back on and it immediately started an array rebuild (4x3 TB Toshiba disks, X-RAID). While it was rebuilding, I was able to view and access files on the NAS throughout the day (the rebuild took around 14 hours).
When the rebuild completed, I tried to access my files and received errors, so I rebooted the device. Once it came back up, it no longer shows my volume from the array, although it shows all disks as healthy. I suspect/hope that the data is intact, but the device just has become unconfigured for accessing it. I have ssh access, but I need guidance for how to go about recovering this.
Have you downloaded the full log zip file? There are likely more clues in the logs.
tyrrminal
Jul 22, 2023Aspirant
The Logs section of the Dashboard just says "No Logs" and the Download Logs button does nothing
