nickjames
May 13, 2017Luminary
Volume operations causing slowness across SMB
Greetings! I'm trying to understand the behavior that I'm experiencing, whether or not its expected and most importantly, how can I improve it. We are a graphic design shop. We use a lot of Adob...
jak0lantash
Jun 04, 2017Mentor
Also, the throughput is only as good as the slowest link in the path. So if your test PC is connected to switch A via a single Ethernet cable, you won't see more than 1Gbps (so <125Mo/s - overhead).
