Cazzbags
Sep 26, 2018Aspirant
Volume Redundant
Not sure why but my last post disappeared without warning... however I'll try again.
I inserted a second disk into my 4 bay last night as I had been running on only one disk for some time.
This l...
- Sep 27, 2018
Cazzbags wrote:
if it's healthy, what does redundant mean? Where to from here? Do I need to replace a drive?
RAID redundancy means that your volume is protected from an ordinary drive failure. In normal situations, your data will remain fully available even if one disk fails. So it is part of the healthy status, and you don't need to replace a drive.
But by saying "ordinary drive failure" and "in normal situations" I am pointing out that you can't depend on RAID as a backup. There are several scenarios where the RAID redundancy won't protect your data. You need at least one copy on another device to do that.
If you don't already have a backup plan in place, then that would be a good next step. The least expensive approach is to back up the files to USB drives. It is also possible to back up the NAS to cloud storage or to another NAS.
Sep 27, 2018Guru - Experienced User
Cazzbags
Sep 27, 2018Aspirant
Oh ok great thank you. Sorry if it was a dumb question. I tried to Google it and searched this forum but nothing was coming up explaining what it meant so I went on standard definition of the word. Thanks for explaining it. Appreciate it.
