truittvance
Jul 10, 2012Aspirant
Volume scan
Greetings, Each time I reboot by readynas pro I get this email: Volume scan found errors that it could not easily correct. Please ensure that you have current backups of all valuable data befor...
truittvance
Jul 12, 2012Aspirant
Ok, that is all fine, I guess I left out an important piece of info: everytime I boot the unit it goes through the file system check, even when I try to boot normally. This takes a long time and is very boring for everyone in the office. I thought if I did the fsck "manually" like the warning suggested it might be able to fix the error and would quit doing a check every time I boot. Is there a next level, ie what do you do if the fsck isn't able to find the errors and keeps checking on every boot?
Not sure if this is related or not, but I can no longer boot from frontview, I have to physically walk in there, touch the button, wait for it to get ready to shut down, press to shut down, and the fire it back up. Thanks for your continued help!
- Sep 11, 2022Retired_Member
