truittvance
Jul 10, 2012Aspirant
Volume scan
Greetings, Each time I reboot by readynas pro I get this email: Volume scan found errors that it could not easily correct. Please ensure that you have current backups of all valuable data befor...
OOM-9
Jul 16, 2012NETGEAR Expert
I have confirmed this is normal behavior with the newest firmware. You will need to manual command the NAS to run the FSCK. Since the FSCK has helped you in the pasted
We were trying to help control the FSCK from destroying the data. Informing you guys to backup the data before it forces the changes to the FS.
In the meantime, you can run the FSCK manual, or if you wanted to reboot; there is an option to skip FSCK.
