jdr03
Nov 04, 2015Aspirant
Volume Size incorrect on RN314
Hi, I have a ReadyNAS RN314 and when I set it up a few weeks ago, I used 3 x 2TB drives. From memory, this reported the effective disk space as 3.45TB which seemed ok to me. Over the last few da...
- Nov 04, 2015
Your volume is currently resyncing. I would wait for this sync to complete.
mdgm-ntgr
Nov 04, 2015NETGEAR Employee Retired
Have you tried a reboot?
Please send in your logs (see the Sending Logs link in my sig)
jdr03
Thanks for the quick reply. I have emailed the logs now.
I have rebooted approx 3 times without any difference in the reported volume size.
- mdgm-ntgrNov 04, 2015NETGEAR Employee Retired
- jdr03Nov 04, 2015Aspirant
Ok, I'll do this before reporting back. Thanks again for the quick replies.
- SkywalkerNov 04, 2015NETGEAR Expert
It's still working on it. Once the RAID reshape is done, it'll grow to use the new space.
In the future, if you plan to replace *all* the drives with larger drives in one shot, it'd be quicker to just switch to Flex-RAID mode. Flex-RAID will still expand automatically, but not until all the disks in the system have available space. X-RAID does immediate incremental expansion, which requires a lot more data shuffling.
Thanks for the tip Skywalker. I obviously wrongly assumed that once the status returned from degraded to redundant that it was ok to change another disk.
Resync is at 75% and I'll hopefully see the extra space in a few hours time.
