davidr1
Oct 05, 2016Luminary
Volume Warning on Disk Useage
Last weekend I ran Disk Test on my: NAS314 4TB x 2 ReadyNAS Pro 2TB x 2 ReadyNAS Ultra 1TB x 2 all running OS 6.6.0 Since then I have had aletrs every boot on the Pro: Less than 30% of volum...
- Oct 06, 2016
already removed the files that were on the root volume.
Looks like your USB disk is connected now and is only 80GB?
mdgm-ntgr
Oct 05, 2016NETGEAR Employee Retired
What do you see for the data volume at the top of btrfs.log?
davidr1
Apologies for a silly question - which log is the btrfs log?
- mdgm-ntgrOct 05, 2016NETGEAR Employee Retired
One of the logs in the logs zip download when you download the logs.
- davidr1Oct 05, 2016Luminary
Probably best to paste the log - at thre risk of causing annoyance :-)
Please note I don't take Snapshots
Label: '1af911e4:root' uuid: 53aeb8ba-5b5e-412e-a449-7a719c46315e
Total devices 1 FS bytes used 2.90GiB
devid 1 size 4.00GiB used 4.00GiB path /dev/md0
Label: '1af911e4:data' uuid: f0e6d972-5d56-4a0c-b98d-3829e74c6b0a
Total devices 1 FS bytes used 400.55GiB
devid 1 size 1.81TiB used 636.06GiB path /dev/md127
=== filesystem /data ===
Data, single: total=629.00GiB, used=399.93GiB
System, DUP: total=32.00MiB, used=128.00KiB
Metadata, DUP: total=3.50GiB, used=633.62MiB
GlobalReserve, single: total=224.00MiB, used=0.00B
=== subvolume /data ===
ID 256 gen 164254 top level 5 path home
ID 257 gen 168010 top level 5 path .apps
ID 258 gen 9 top level 5 path .vault
ID 259 gen 106335 top level 5 path .timemachine
ID 264 gen 165494 top level 5 path ._share
ID 284 gen 105400 top level 5 path .purge
ID 289 gen 1838 top level 256 path home/david
ID 999 gen 167022 top level 5 path Backups_Weekly_of_Ultra
ID 1000 gen 53261 top level 999 path Backups_Weekly_of_Ultra/.snapshots
ID 1003 gen 168228 top level 5 path database
ID 1004 gen 53289 top level 1003 path database/.snapshots
ID 1005 gen 166660 top level 5 path documents
ID 1006 gen 53307 top level 1005 path documents/.snapshots
ID 1007 gen 165660 top level 5 path filing_cabinet
ID 1008 gen 53321 top level 1007 path filing_cabinet/.snapshots
ID 1009 gen 168063 top level 5 path financial
ID 1010 gen 53335 top level 1009 path financial/.snapshots
ID 1011 gen 167136 top level 5 path howtos
ID 1012 gen 53349 top level 1011 path howtos/.snapshots
ID 1013 gen 168063 top level 5 path software
ID 1014 gen 53363 top level 1013 path software/.snapshots
ID 1120 gen 157304 top level 5 path copies_of_usb
ID 1121 gen 82774 top level 1120 path copies_of_usb/.snapshots
=== btrfs-show-super /dev/md0 /dev/md127
superblock: bytenr=65536, device=/dev/md0
csum_type 0 (crc32c)
csum_size 4
csum 0x0388df90 [match]
bytenr 65536
flags 0x1
( WRITTEN )
magic _BHRfS_M [match]
fsid 53aeb8ba-5b5e-412e-a449-7a719c46315e
label 1af911e4:root
generation 77005
root 50249728
sys_array_size 226
chunk_root_generation 76638
root_level 0
chunk_root 20987904
chunk_root_level 0
log_root 0
log_root_transid 0
log_root_level 0
total_bytes 4290772992
bytes_used 3117309952
sectorsize 4096
nodesize 16384
leafsize 16384
stripesize 4096
root_dir 6
num_devices 1
compat_flags 0x0
compat_ro_flags 0x0
incompat_flags 0x21
( MIXED_BACKREF |
BIG_METADATA )
cache_generation 18446744073709551615
uuid_tree_generation 77005
dev_item.uuid f53fd2a9-3d56-4968-b810-0880bb893e75
dev_item.fsid 53aeb8ba-5b5e-412e-a449-7a719c46315e [match]
dev_item.type 0
dev_item.total_bytes 4290772992
dev_item.bytes_used 4290772992
dev_item.io_align 4096
dev_item.io_width 4096
dev_item.sector_size 4096
dev_item.devid 1
dev_item.dev_group 0
dev_item.seek_speed 0
dev_item.bandwidth 0
dev_item.generation 0
superblock: bytenr=65536, device=/dev/md127
csum_size 4
csum 0x0fe6e38c [match]
bytenr 65536
flags 0x1
( WRITTEN )
fsid f0e6d972-5d56-4a0c-b98d-3829e74c6b0a
label 1af911e4:data
generation 168228
root 272433152
sys_array_size 129
chunk_root_generation 167111
root_level 1
chunk_root 473583157248
chunk_root_level 1
log_root 271941632
log_root_transid 0
log_root_level 0
total_bytes 1995430690816
bytes_used 430085808128
sectorsize 4096
nodesize 32768
leafsize 32768
stripesize 4096
root_dir 6
num_devices 1
compat_flags 0x0
compat_ro_flags 0x0
incompat_flags 0x21
( MIXED_BACKREF |
BIG_METADATA )
uuid_tree_generation 168228
dev_item.uuid 0bb5e8ca-dc1e-4405-a78b-213348e72abf
dev_item.fsid f0e6d972-5d56-4a0c-b98d-3829e74c6b0a [match]
dev_item.type 0
dev_item.total_bytes 1995430690816
dev_item.bytes_used 682966908928
dev_item.devid 1
dev_item.generation 0- mdgm-ntgrOct 05, 2016NETGEAR Employee Retired
Looks like it's the 4GB root volume that's getting full.
Is there an erroneous mention of a media volume in fstab?
