davidr1
Oct 05, 2016Luminary
Volume Warning on Disk Useage
Last weekend I ran Disk Test on my: NAS314 4TB x 2 ReadyNAS Pro 2TB x 2 ReadyNAS Ultra 1TB x 2 all running OS 6.6.0 Since then I have had aletrs every boot on the Pro: Less than 30% of volum...
- Oct 06, 2016
already removed the files that were on the root volume.
Looks like your USB disk is connected now and is only 80GB?
davidr1
Oct 06, 2016Luminary
Hi mdgm,
Thanks for replying.
I'm not sure what you mean by
You had a backup job that was writing to /media/USB_HDD_1 but there is no USB hard disk mounted there.
It is correct that unattended backups may be scheduled but for human reasons the drive may not be connected or the NAS not recognise a backup drive is connected.
Surely in those instances an error occurs indicating the device can not be found?
If you mean a job was running but the backup drive was disconnected before completion that has not occurred unless there was a power outage.
What can I do to recover the space in /root?
Many thanks,
David
mdgm-ntgr
Oct 06, 2016NETGEAR Employee Retired
- davidr1Oct 07, 2016Luminary
Thanks mdgm.
Yes, that NAS only has < 80GB data to backup daily. Other backups are larger to other disks.
Thanks for clearing the problem - no alert today :-)
