PeteC2017
Jan 30, 2023Aspirant
Volumes now showing inactive after reboot
on one of our ReadyNAS 4312 after a reboot all the disk in the Raid 5 are showing as inactive. nothing has been written to the NAS. Isa there a way to bring the drives on line and recover the data ...
PeteC2017
it looks like some sort of OS issue, I cannot add SHH servicers.
Jan 30, 2023Guru - Experienced User
Have you been able to download the log zip file?
- PeteC2017Jan 30, 2023Aspirant
yes
- StephenBJan 30, 2023Guru - Experienced User
PeteC2017 wrote:
yes
You should be able sort out what happened by looking at system.log, kernel.log, and systemd-journal.log. A single disk failure should have mounted ok, something must have happened to at least one other disk (possibly just out of sync).
how would I resync them
