PeteC2017
Jan 30, 2023Aspirant
Volumes now showing inactive after reboot
on one of our ReadyNAS 4312 after a reboot all the disk in the Raid 5 are showing as inactive. nothing has been written to the NAS. Isa there a way to bring the drives on line and recover the data ...
NiveditaP
Apr 03, 2023NETGEAR Employee Retired
Hello PeteC2017
Could you please look into the disk logs , if ATA Error count is greater than 0 then it seems your drive have gone faulty.
Also, if you are using Raid 5 then the NAS should work with 3 drives.
Have a lovely day,
Nivedita Pa
Netgear Team
- SandsharkApr 04, 2023Sensei
ATA errors are not always due to the drive. SMART can't determine if it's the hardware on the drive side, the NAS (PC, etc.) side, or even another drive on a companion SATA bus. I had an EDA500 on which the eSATA cable became loose, and the result was dozens of ATA errors before the volume was corrupted and went read-only.
- StephenBApr 04, 2023Guru - Experienced User
Agreed. And a non-zero ATA count doesn't necessarily mean the drive needs to be replaced. I've seen cases where drive X has failed to respond to a command, and an ATA error was then reported on Drive Y. I'm thinking that the SATA bus ended up hung, and that the OS couldn't figure out what drive was at fault.
In this case PeteC2017 says there was one failed drive though, so I do agree that looking at the smart stats (and the other logs) was the right next step. I said that earlier in the thread.
In any event, the posts are quite stale (2 months old), so I don't why the mod decided to reply now.
