DoctorBrown
Jan 18, 2016Apprentice
Wake-on-LAN always powers up NAS
The Wake-on-LAN feature appears to be completely broken on my ReadyNAS 102. If the WOL feature is enabled in the Power settings, the system will not stay powered off if the network cable is plugged i...
- Jan 18, 2016
There is a fix for this in 6.4.2 RC1 https://community.netgear.com/t5/ReadyNAS-Beta-Release/ReadyNASOS-6-4-2-RC1/m-p/999457#U999457
So one option is to install that.
You can manually downgrade to 6.4.0 (but not before). However if that is the only issue you are having, then I'd suggest going with 6.4.2 beta instead.
Jan 18, 2016Guru - Experienced User
- DoctorBrownJan 18, 2016Apprentice
StephenB, Thank you for the very quick reply! I upgraded to the 6.4.2 RC1 and it solved the problem.
