IamMoody
Jul 31, 2017Guide
Way to hide default 'data' Share?
In windows file explorer I've got a share folder, named 'data' which contains 0 bytes, but leads to a copy of the other data which I have on the drive. This share is not visible in the Web GUI. I'm w...
- Aug 01, 2017
I suspect you are using the NAS admin credentials in Windows. That will let you see the full data volume - which by default is named "data".
If so, you are not seeing a copy of the files and folders. You are seeing the actual files and folders - you are just accessing them using a different path. The data volume also has other folders that are not shares - for instance, you can see the home folder, and if you show hidden folders you will see .apps and a lot of other stuff.
All top-level shared folders will show 0 bytes if you right-click on them and look at properties. That doesn't mean they are empty.
IamMoody wrote:
and if there is a way to delete or hide it? I've got another of the same NAS that isn't displaying this behavior.
Hopefully it's clear now that you don't want to delete it - you'll lose your data if you try.
The way to hide it is to use different credentials with the NAS. For instance create a user account on the NAS (maybe call it user), and assign it a password. Then delete any current credentials for the NAS in windows credential manager, and create a new one that uses your NAS user account/password.
Aug 01, 2017Guru - Experienced User
