tccack
Jan 29, 2012Aspirant
wbadmin, wireless and failures
Hi there... I am having a really frustrating time trying to create a windows complete backup on my NV+. I found out that network drives are not visible to the GUI method of the complete backup in Vi...
quickly_now
Jan 30, 2012Apprentice
My experience has been that backup over wireless is slow and can be unreliable.
If you want a reliable backup - don't use wireless. (Just don't do it!)
The permissions issues will depend on what backup s/w you are using (you did not say); it may also depend on whether or not the backup is being done from a volume snapshot using Windows VSS. In general, you should not see permissions problems.
