LDG
Apr 19, 2016Aspirant
WD Compatibility
Two questions: 1. I have two WD Elements and one WD My Book. I did a brief search for compatibile drives with the 104 and only came up with about three for WD. Is that right or was I looking i...
Apr 19, 2016Guru - Experienced User
LDG wrote:
Two questions:
1. I have two WD Elements and one WD My Book. ...Will my drives work in this NAS?
These are USB drives, correct? The HCL Brian mentions is for internal hard drives that are installed in the NAS.
The NAS is not a USB dock - it is intended to be used with internal drives like the WD40EFRX.
LDG
StephenB wrote:
LDG wrote:Two questions:
You are correct! My plan is to remove the drives from their enclosures. Way out of warranty on all three. I forgot to mention that detail when I posted this. Will this still work?
